Login Error
Close
Vinyl vs Aluminum Awning Windows
by DoItYourself Staff
Both vinyl and aluminum awning windows have their advantages. Each type can also have drawbacks. The best type of window will depend on your needs. This simple guide will point out the differences, advantage, and disadvantages of each.
Aluminum awning windows are inexpensive to install. They will withstand all weather elements, and can be customized to any size. Aluminum is available in many styles and colors, and can be painted later if you decide to change the look of the exterior of the home. Aluminum will require some basic maintenance to prevent rust. The awning material can be sprayed with a rust preventative to minimize the risk. Aluminum can also dent during heavy weather, such as hail storms.
Vinyl Awning Windows
Vinyl awning windows will cost a little more, but for some people are a better option. Vinyl is simple to install, and is virtually maintenance free. Since the vinyl material is created with the color infused in the material, repainting won't be necessary after time. Vinyl will also withstand weather without sustaining heavy damage. For those who enjoy changing the exterior look occasionally, this may not be a good option. Vinyl is hard to paint, and can be expensive to replace frequently.
 forum activity
