Login Error
Close
Vinyl vs Aluminum Window Frames
by DoItYourself Staff
When choosing what type of window frames you want to use for home, you can choose between vinyl and aluminum window frames. Before purchasing, you need to know the difference between the two.
Cost Difference
Aluminum frames do not need to be replaced entirely. Only replace the windows that have been damaged. Vinyl window frames, on the other hand, need to be replaced entirely because it is difficult to match the frame with the existing window you have. This makes aluminum frames more cost-effective than vinyl window frames.
Noise Reduction
Aluminum window frames can keep outside noise away better than vinyl window frames. This is a result of a series of studies conducted by competent groups.
Insulation
You can acquire better insulation if you use vinyl frames. This will keep out heat and cold better than aluminum frames.
Maintenance
Aluminum window frames need to be repainted every once in a while since the color can chip off. Vinyl frames hardly need any painting since their color lasts for much longer.
Strength
Aluminum window frames are more durable. They can therefore stand stronger winds and much harsher weather conditions.
Moisture
Aluminum window frames are more susceptible to moisture which can cause damage. Vinyl frames can resist snow and rain conditions better.
 forum activity
