Login Error
Close
Vinyl Vs. Steel Siding: Which Is Better?
by DoItYourself Staff
Choosing the type of siding for your home doesn’t have to be a daunting task. Read this simple article to help decide which siding choice is best for your home.
Cost
Steel siding will cost more than vinyl. If you are planning on only being in the home for a short period of time, the steel may not be worth your money. In most cases it will be almost double the cost of vinyl.
Durability
If you are planning on being in your home for some time, then steel may be the way to go. It’s more durable, won’t crack or buckle, and is much harder to damage. Vinyl siding is pretty durable and withstand weather, but it won’t always last a lifetime like steel will.
Installation
Installing vinyl is much easier than installing steel. Steel will require a lot of hard work on your hands, and is much less forgiving than vinyl. If you are looking for a do it yourself project, then vinyl may be the best choice.
When you decide on which material works best for you, you need to consider the length of time you will be in your home, the conditions, and your budget. As long as you keep these in mind you will be able to find the best choice for your needs.
 forum activity
