VoIP Alarm Monitoring
Having an alarm system is an important step to keeping yourself, your family and your possessions safe and alarm monitoring is important to its success. With advanced computer technology alarm monitoring has also taken a huge step forward but, in some ways, has not progressed enough. This article will address VoIP alarm monitoring.
VoIP Explained
The VoIP phenomenon is an important technology that takes away someone's need for land line phone service. It stands for "Voice over Internet Protocol". VoIP uses the Internet to transfer voice data for a cost that is less than phone service from a nationwide telephone company.
VoIP and Alarm Monitoring
Alarm systems are designed to work over analog lines and not digital. VoIP is purely digital so the alarm monitoring has to be changed from analog to digital and then back again. This is where issues with VoIP alarm monitoring begins as interference and signal degradation cause the alarm monitoring to fail. VoIP is also prone to dropped calls and, unlike land line phones, will use power in a power failure.
Signal Relays
In order to utilize VoIP alarm monitoring you will need a signal relay. These are broadband adapters you connect to the VoIP system to handle the signal transformation.
