Login Error
Close
Wainscoting Bathroom Guide
by DoItYourself Staff
what you'll need
  • Wainscoting
  • Chair Rail or Crown Molding
  • Baseboard
  • Measuring Tape
  • Level
  • Pry Bar or Chisel
  • Hammer
  • Construction Glue or Paneling Nails
  • Circular Saw
If you are looking for inexpensive ways to update the value and beauty of your home, follow this wainscoting bathroom guide and you will be pleasantly surprised.
What is Wainscoting?
Wainscoting is a type of wood paneling that can be used throughout a home to update and add style to the décor.  It comes in different types and styles, so educate yourself before purchasing.  The great thing about decorating with wainscoting is that it is relatively easy to install and is inexpensive. Wainscoting comes in panels of 4 feet by 8 feet sheets and is used to decorate the bottom three feet of the wall.
Types
There are two basic types of wainscoting.  There is pre-finish or ready-to-finish.  Among those two types there are several different styles.  The most popular style to decorate a bathroom is the flat panel, such as beadboard.  Beadboard is a narrow and flat panel.  The other styles, some of which are raised or grooved, go well in other parts of a home; such as a formal dining area or bedroom.
The beadboard, or flat panel, for your bathroom is most commonly found in white and looks terrific with a contrasting color painted on the wall above it.
Installation
Step One – Purchase
The first thing you will need to do will be to choose and purchase the style of wainscoting, molding and baseboard that you want in your bathroom. Be sure to measure the walls accurately and buy slightly over that amount.
Step Two – Acclimate Wainscoting
Wainscoting is a wood product, so it may need to sit in your home for a day or two before installation. This is simply to allow for any adjustments the wood needs to make for temperature and humidity change. It may expand or contract and you want that to happen before you get it on your wall.
Step Three – Remove Old
In the mean time, you can remove all the outlet and switch covers as well as use your pry bar to remove all the old moldings and baseboards in order to prepare for installation of the new.
Step Four – Alignment
Using your tape measure and level, mark out the top of the line where wainscoting will lay. Remember it won’t matter if there are slight gaps at the bottom because the baseboard will cover it. Most homes have slight variations in the floor. The important thing is that the top is even.
Step Five – Install
Now you can begin to install the panels to the wall. It’s a matter of personal preference whether you use carpenter’s glue or panel nails. Install one panel at a time until walls are covered as preferred. You will need to use your circular saw to adjust pieces for shape around outlets and whatever else.
Step Six – Finishing Touches
You are now ready to install the chair rail to the top of the wainscoting and the baseboards to the bottom. You can also do any painting that you desire before reattaching the outlet and switch covers.
 forum activity
