cancel
Job type :
Zip Code :
community forums
comments
Wall Sheathing
While building a house you don't want to forget to put up the wall sheathing. Wall sheathing is made up of large panels of wood that have been place over the frame on the exterior of the house. It is over the top of this wood that you place the foam insulation. There are always a few things to remember when installing wall sheathing.
• Make sure you pick out the right grade of wood. Plywood is graded on its front and back, so make sure you have a high grade facing the outside to help protect the house from weathering.
• Check to see how many pieces of wall sheathing you will need before you purchase them. Make sure you purchase an extra piece in case you mess up a cut or need extra.
• Lay the wall sheathing over the 2x4s and screw or nail them down firmly. Make sure the wall sheathing has as few cracks as possible.
Structural Wall Sheathing
For areas that must withstand hurricanes or high winds there is structural wall sheathing. This type of sheathing has extra support, so that it will not peel away in strong winds. It also helps hold the entire frame of the house together during a strong storm.
member comments
Related Articles
Elements of an Energy Efficient HouseElements of an Energy Efficient House
Elements of an energy-efficient house... read more
How to Frame a Pony Wall
A pony wall is a low wall used to divide rooms physically, while still leaving... read more
How to Prepare Walls for Brick Veneer
Preparing the exterior surface of a wall for a brick veneer is a simple and... read more
articles we like
Ribbon
In construction terms a ribbon refers to a board or lengths of board which are... read more
Do It Yourself Gutter Repair Tips
Advice and tips for cleaning and repairing your home's gutters... read more
Protect Your Valuable Stuff When You Travel this SummerProtect Your Valuable Stuff When You Travel this Summer
Sunny skies, warm tropical breezes, fun in the sun. Summer vacation will be here... read more
sponsored articles of the day
diy centers
