Login Error
Close
Wall Stencil Designs: 2 Stencil Ideas
by DoItYourself Staff
If you plan to decorate your home with stenciled patterns on your walls, you will need one or more wall stencil designs before you begin. Luckily, there are plenty of types of designs to choose one, and you should have no trouble thinking of one you like. The following example ideas should help you to get started, but they should not limit your imagination if your interests lie in a different area.
Floral Print
Floral print is an obvious choice when decorating your home using wall stencils. With it, you can make an intricate pattern that still fits in with your other decorations. Floral print makes great borders, so you should definitely think about letting a border wrap around your floor or ceiling. You can find many floral patterns in books of clip art, or online as well.
Abstract
There are many advantages to using abstract designs. For one thing, they are easy to make, as simple, bold shapes are often best. Also, they can be used in any situation. Whether you need a border, a column, or something else, there is an abstract design that will fit. In general, you can freehand your own abstract designs, but there are plenty of sources of them as well.
 forum activity
