cancel
Job type :
Zip Code :
community forums
comments
Wallcovering Adhesive
Wallcovering adhesive is used to prepare a wall to hold paper and other types of covering.  Generally found in liquid or paste form, wallcovering adhesive does come in several different varieties.
Wallcovering adhesive types
There are a number of different wallcovering adhesive types. They include:
  • Pre-pasted activators – This type of wallcovering adhesive is meant for use with wall coverings that come with adhesives already in place. Do-it-yourself wall paper rolls, for example, often are self-adhering. The activators simply make this style of paper easier to hang and more durable over time.
  • Clear – Wallcovering adhesive products of this type have a clear appearance and do not dry quite as fast as other options. They are also much easier to clean up after using.
  • Clay – This type of wallcovering adhesive is thicker and messier than the clear variety. It is generally used by professional hangers or painters.
  • Vinyl – This type of wallcovering adhesive is used to apply vinyl to a wall. This type of adhesive is considered permanent once it dries.
Considerations when using wallcovering adhesive
Before selecting or using wallcovering adhesive, make sure to study the material involved for hanging. Vinyl, for example, will require a different type of adhesive than paper or fabric.
member comments
Related Articles
How to Shop for Wallpaper
How to shop for wallcoverings/wallpaper... read more
Easy Hang Wallpapers Take the Fear Factor Out of InstallationEasy Hang Wallpapers Take the Fear Factor Out of Installation
Blank walls in need of a makeover almost always beg the question: What color to... read more
Common Wallpaper and Wall Covering Problems
Frequently Asked Wallpaper and Wallcovering Questions FAQ's... read more
articles we like
Dry Cleaning
The process of dry cleaning, just as the name implies, is cleaning garments and textiles... read more
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
What Do Employers Want? Smooth Talkers, Good Readers
The following article discusses how the ability to communicate effectively can land you a secure,... read more
sponsored articles of the day
diy centers
