Login Error
Close
Wallcovering versus Paint
by DoItYourself Staff
Paint is great, but a wallcovering is better. There are many reasons to back this theory up. One main reason is that it is beautiful, yes paint can be too, but wallcovering offers a professional look without the use of a professional. Paint can not hide imperfections in your walls, a wallcovering can.
When you paint your walls and see the many little imperfections that end up driving you nuts, you can try to fix it yourself, hire a professional or use a wallcovering. Trying to fix it yourself can be a hassle; if you do not know what you are doing you could make it worse. Hiring a professional is expensive, although the job will be done right. Using a wallcovering allows the job to be done right and without hiring anyone to do it.
Where to Use Wallcovering
Wallcovering can be used in any room and on any wall. If you have drywall, plaster, or even wood paneling a wallcovering can be used. The vinyl wallcovering is a great solution to a kitchen or bathroom wall where you will need to scrub more often.
The beauty that a wallcovering can bring a room makes is versatile enough to use just about anywhere. There are many different styles and designs to choose from, smooth, textured, and even paintable.
 forum activity
