Login Error
Close
Wall-Mounted Fireplaces: Pros and Cons
by DoItYourself Staff
Wall mounted fireplaces can light up a room, warm it up and even save you money all at the same time. In addition, wall-mounted styles can run on either gas or electricity, and they may be mounted on a wall or placed against a wall. There are both advantages and disadvantages to this type of style, so read on to decide whether a wall-mounted fireplace is right for your home.
Less Mess
Among the several advantages of a wall-mounted fireplace is that it is not as messy as a regular fireplace. It basically works with an On and Off switch or it is plugged into the wall. It doesn’t require fuel, logs or even a match.
No Chimney Clean-Up
Because you do not need a chimney or fireplace flue with a wall-mounted fireplace, there is no added expense like a chimney sweep. You also save money on buying logs, wood, matches and the like that you would have to buy for a gas fireplace.
No Fumes
A wall-mounted fireplace produces no smoke. This eliminates the possibility of your inhaling hazardous materials or fumes and from smoke damaging your walls or ceiling.
Warm Settings
Many wall-mounted fireplaces have a simple switch that can activate the unit itself to radiate a heat level or just turn the flame on alone. These units are often stronger and more attractive than a regular room heater.
Space Savings
For those with smaller areas or live in condominiums or apartments, a wall-mounted fireplace takes up little space. Some units can be hung on a wall rather than take up floor space. They are also portable and can be taken from room to room whereas a conventional fireplaces is stationary.
Money Savings
An electric wall-mounted fireplace runs on electric and can save money in the long run on your utility bills.
No Waiting
With a turn of a switch, you can turn off a wall-mounted fireplace whereas you might have to wait until the last ember dies with a regular fireplace.
No Remodeling
You will not have to remodel anything in the home if you decide to add a wall-mounted fireplace. All you need is a wall socket where you can plug in the unit to fire it up and feel the heat or just enjoy the look of a flame.
Less Heat
A wall-mounted fireplace never throws as much heat as a gas fireplace and where an additional log can be then on the fire, a wall-mounted fireplace does not have that option.
Real Look
Some people prefer the look of a real fireplace as opposed to a wall-mounted fireplace—which can often look faux depending on the manufacturer of the unit.
No Added Value
Because a wall-mounted fireplace is portable, it probably will not add value to the home if you were to sell it. Many home buyers are looking for a real fireplace in a main room or family room.
 forum activity
