Login Error
Close
Washer-Dryer Combo Advantages and Disadvantages
by DoItYourself Staff
Gadgets are made for simplifying our lives; the washer dryer combo is a classic example to substantiate it. It is a godsend for those who are juggling multiple activities everyday. The changing times have always influenced the customer needs. For this reason, the simple washing machines have made way to the more efficient washer dryer combos available in the market today. Here are some facts of the washer dryer combo you may want to know.
Advantages
Easy to Use
You don't have to get your laundry done from outside. You don't even have to worry about manually moving the clothes form the washer to the dryer. Those obvious reasons apart, there are a few more not-so-obvious reasons for which you could consider owning a washer dryer combo
They are Compact
The washer dryer combos are compact machines that could fit into any home. They do not occupy more space. This machine would not be bigger than a dish-washer but could help you do your laundry at home, at your time of convenience. They usually come with wheels, so it would be easy for you to move them as needed.
Save Energy
With more and more people getting conscious about the depleting ozone layer and receding natural resources, saving energy is the top priority. Washer dryer combos come with a promise to save energy, as a proof of which they are Energy Star rated. They use water and electricity very efficiently. You could now pamper yourself with some luxury with no sense of guilt.
Added to the above are other features where the water level will be automatically detected by the machine, you could time the machine to run at a later point of time; commonly called the delayed start feature, you could benefit from different settings for different kinds of clothes and many others.
Disadvantages
Though the washer dryer combo sounds powerful and promising, there are a few things you may have to keep in mind while making your decision.
They Have a Limited Capacity
The washer dryer combo can accommodate fewer loads compared to a simple washing machine. This is because the clothes will spin when they are being dried unlike in the case of a simple washing machine. The vibration from the machine is usually an annoying factor for many. There are many companies taking special care to minimize the vibration, a point worth remembering while purchasing the washer dryer combo.
Time Consuming
The washer dryer combo takes a lot of time to give you the benefit of neatly washed clothes. On an average, clothes that weigh between 4-5 pounds would keep the machine working for no less than 4.5 hours. This is no miracle in a jiffy so you cannot escape from planning to do the laundry well ahead.
The washer dryer combos come with both advantages and disadvantages. If you think you could work around the disadvantages or you simply find them tolerable, then they are worth a buy. It is better to inquire about the service centers and availability of spare parts before deciding on the right brand and model to buy.
 forum activity
