Washers & Dryers
If you are in the market for a new washer and dryer, you have a lot of factors to consider. Your main concerns are probably cost, energy efficiency, and performance.
Tips for buying a washer and dryer
Historically dryers outlive their counterparts. So chances are you will just be replacing a washer. It should be noted that washer performance has changed recently due to the fact that U.S. Department of Energy requires new washers to use 21% less energy than older models. This is their way of conserving energy, saving the environment and going green.
So now, more than ever it is essential to do your homework before spending money on a household appliance that does not work under the same performance levels. You should research both top and front loading machines to find out which give the optimum cleaning results.
Saving money when purchasing a washer and dryer
If your washer breaks down, does this mean that you really need a new dryer as well? If you don’t need a new dryer, don’t buy one. How important is it to have a matching set that is hidden in a closet or laundry room?
Some newer washers have special settings like Active Wear and accessories like storage drawers. They are now also manufactured in bright, inviting colors. Don’t let these unnecessary bells and whistles divert your attention away from performance factors.
