Login Error
Close
Washing Machine Motor Repair Mistakes to Avoid
by DoItYourself Staff
A washing machine motor needs to have proper maintenance and suitable repair once it experiences failures. If you notice that something is wrong with your washer motor, do not take it for granted. Instead, repair it at once to avoid worsening and committing unnecessary washing machine motor repair mistakes.
Repairing Alleged Water-Related Problems
In order to repair your washing machine you need to check the troubleshooting list first. Watch out for the usual washing machine problems, like belts, water-related problems, pulleys and the motor. The washing machine motor is a significant part of the entire machine’s function. Often, repairmen want to perform repairs with used or old parts. That is why if you can repair the washing machine motor on your own, the better.
First check the water drain. Ensure that no objects obstruct the drainage. The outer tubes, which serve as the ditch of the water, should be checked as well for any break or barriers.
Washing Machine Motor Spinner Troubleshooting
Washing machines, just like any typical mechanical devices, occasionally requires servicing. One of the most common problems involves the motor spinner. Still, you need to check it several times before doing any repair to your washing machine motor spinner. Take a look at the agitator as well. It should be seated perfectly by opening the washing machine’s lid. If it is loose, pop off the agitator’s top and then tighten the bolt that holds the agitator in its correct place. Take out the access panel at the rear of the washing machine through unscrewing the screws gripping it in place. This permits access to the washing machine drive motor. Push the drive belt that works with the agitator.
False Transmission Replacement
The latest washing machine models make use of a direct-drive system to spin and agitate. They do not use pressure wheels or belts to transfer motion and power from the washing machine motor towards the transmission. This motor is coupled straight towards the transmission. Once the motor is operating and there is no spinning or agitation of the tub, the culprit is typically a plastic coupling amid the transmission and motor.
 forum activity
