Waterproof Decking: 2 Materials to Consider
There are several materials people are now using for waterproof decking. For years, wood has been used as the major component of a deck. Although wood has a low cost and is easy to work with, it can be very difficult to maintain over the years. Due to its rotting properties, repetitive staining is required over time which can get costly and time consuming. Also, splinters are formed in wooden decks when exposed to environmental conditions and can cause harm. Algae and mold formation due to moisture is another problem. Waterproof decking is the answer to all of this.
Alternative Materials
Working with alternative materials has been very easy today. There are materials like plastic, composite and aluminum that are easy to work with and relatively require almost no maintenance when compared to wooden decks. The materials are also environmentally friendly, usually made from recycled materials. There is no harm from the alternative materials like the harm that comes from pressure-treated wood that is coated with harmful chemicals. The impact on the environment is already enough when a lot of wood is used for home building. Using an alternative material for a deck is thus an environmentally friendly idea. Choosing the right material for waterproof decking is important though. Here are 2 materials being popularly used for the purpose.
Aluminum Decks
Aluminum is one of the most popular materials being used for waterproof decking. Aluminum decks have proven to be water-resistant and corrosion-free over years. They are also extremely durable and can withstand harsh environmental conditions. Being lightweight, aluminum can be super-easy to work with when compared to working with wood. Also, its reflective properties can ensure that an aluminum deck stays cooler in the summer. Wooden decks can get really hot when the sun is shining bright.
Moreover, some places prone to snow and ice are ideal for using aluminum decks as heating strips can be added to them to melt the ice, making the use of aluminum better than wood again. Also, aluminum is resistant to rotting and cracking and can be used in all types of climates.
Plastic and Composite Decking Materials
Initially, plastic and composite materials were very expensive to use for waterproof decking. The price was so high that even smaller decks were not practical to make. The prices have finally come down and due to its long-term maintenance free features, people are finally using the materials for decking. Although still rather expensive, using composite materials for your deck will eliminate the cost of constant staining and maintenance.
This reduction of costs will help you recover your initial investment more quickly over the years. One criticism has been high around using these materials though. Many people have complained of composite decking materials losing their color over time. This issue is now taken care of though. Most companies making plastic and composite decking materials now give a lifetime or limited warranty. In case of fading, you can claim a replacement during the warranty period.
