Login Error
Close
Ways to Clear a Clogged Drain Line
by DoItYourself Staff
A clogged drain line is something to anticipate because it happens one time or another. Some of the most common causes of clogging include grease build-up and debris congestion. Hair, pieces of solid objects, food, and many other types of debris can end up clogging the drain. However, there are some ways to clear the clogged drain line and here they are.
Using the Plunger
The plunger is an elbow grease method that has been used for years. This tool is the first aid for any type of clogging. It forces pressurized air or water to push whatever it is that is clogging the drain. The plunger works best for clogged toilet bowls and other drains where the rubber head can fit into.
Use a Plumber’s Snake or Cable Auger
This flexible steel cable can be used to extricate any debris clogging the drain line. The tool is simply used to hook whatever is clogging the drain line and pull it out. This process requires some elbow grease as well. Simply insert the tool into the drain pipe and use it to find the clog. When there is a resistance, it means that it has hit something. Turn the handle of the device and pull the clog. This method will usually work for solid debris. It will not work for grease clogs though.
Pour Down Hot Water
When grease is clogging the drain line, the best way to clear the clogged drain line is to treat it with hot water. Hot water loosens up the grease and allows it to run down to the sewer. Simply boil a pot of hot water and pour it down the drain. Repeat the process until the grease is removed.
Use Natural Drain Cleaners
Baking soda and vinegar make a good combination when clearing drains. First of all, pour half a cup of baking soda into the drain follow it through with half a cup of vinegar. The mixture will dissolve grease, hair or any other coagulants inside the drain line. Repeat the process until the coagulants are removed. In order to boost the effectiveness of the combination, try pouring a few cups of hot water down the drain to flush out any remaining grease and dissolved debris. Just make sure not to use this combination with any commercial drain cleaners as it may cause an undesirable reaction.
Use Commercial Drain Cleaners
Know that commercial drain cleaners contain toxic and corrosive chemicals. However, if natural drain cleaners do not work, then it is time to use the commercial drain cleaners as a last resort. Drain cleaners usually contain hydrochloric acid, sulfuric acid and other strong acids that dissolve hair, grease and other solid clogs. A clogged drain line may be easily cleared by such chemicals, but make sure to be careful when dealing with these products. Use rubber gloves as much as possible because it may cause an allergic reaction when it touches the skin. Read the instructions on the product carefully before using it.
http://sequoia.internetbrands.com/sequoia/users/writers
 forum activity
