Ways to Deal With Grease in Your Drain Ways to Deal With Grease in Your Drain
Anti-Grease Dish Soap
Caustic cleaner
Hot water
Bleaching agent
Working gloves
Drain grease can be a big problem in your home. As grease accumulates inside your drain, the water passage can constrict causing liquid to overflow from your sink. Once this happen, things can get very messy and smelly inside your kitchen. To remove grease from your drain and save your home from water damage, here are some tips for you.
Step 1 - Prevention Is the Best Option
Prevention is always the best option so make sure that you do not pour grease into your kitchen sink. When preparing food, avoid flushing ingredients such as butter, margarine, lard, fats, and other greasy substances into your sink. To clean off greasy plates and kitchen utensils, soak them in grease dissolving cleaner first to breakdown oil and fats.
For environmental reasons, you should take extra care when using grease dissolving agents at home. Some types of grease dissolving cleaners sold in the market today contain strong chemicals that can be harmful to the environment, so choose your anti-grease cleaners carefully. As much as possible go for those brands that uses bio-degradable ingredients.
Step 2 - Use the Right Dish Soap
Certain types of dish soaps have active anti-grease features that help prevent your sink from getting all clogged up with grease. These types of dish soaps are not meant to remove grease build-up in your drain but rather, they help prevent the grease from building-up.
Step 3 - Use Caustic Cleaners to Clear the Drain
If your drain is clogged with stubborn grease, you may need some caustic cleaners to clear off the blockages. To do this, pour ample amount of concentrated caustic cleaners into your kitchen sink then let it stand for at least an hour. If your sink is badly clogged that water can hardly pass through it, you may need to leave the cleaner on overnight and allow it to eat into the grease blocking your drain. Once the grease has thawed substantially, you may flush your drain with warm soapy water.
When flushing your drain, you may use an air compressor to force the water into the pipe. Keep flushing until the water starts to flow freely down the drain.
Step 4 - Use Homemade Grease Removers
If you are on a tight budget you can cut cost by making your own homemade grease remover. To make your own grease remover, boil some water then mix 1 part of hot water and 1 part of vinegar then pour the mixture into your kitchen drain then let it stand for a few minutes. The hot water will help melt of the grease while the vinegar will eat at the grease sticking on the pipes. After pouring hot water and vinegar mixture into your drain, follow it up with some boiling water. The boiling water should flush the remaining grease from your pipe.
Clogged drains can emit horrible smell that tends to linger inside your kitchen for sometime. To neutralize that awful smell coming from your drain, mix one part of hot water and one part of bleach, then pour the mixture down the drain then follow it up with warm soapy water.
These ways to deal with grease in your drain should get everything flowing again. Just remember to take to prevent future clogs.
