Well Water Filters: How to Remove Carcinogens
what you'll need
- Filter
- Water Testing Kit
When your home water supply comes from a well, you need to be very adamant that you utilize the proper well water filters to remove contaminants and carcinogens from the water.
Step 1 - Install Filter
You will need to purchase and install a well water filter to make your water consumable. The installation process for every filter type will vary according to manufacturer's instructions. The main function of a well water filtration system is to filter the water coming from the well before your family consumes it. The filter will remove contaminants from the water, making it safe to drink. Well water filters use a largest to smallest filtration system, where the largest contaminants are filtered first and then the smaller contaminants are filtered later. Each step in the filtration process will filter a different carcinogen from the water such as sediment, iron and hydrogen sulfide, metals and microbiological contaminants.
Step 2 - Continue Maintenance
Proper maintenance of your well water filter is vital to ensure proper filtration. There are numerous water testing kits that can be purchased and should be used to test the filtration of your water. Be certain to follow all maintenance and use guidelines of your well water filter to ensure your water remains safe and drinkable.
