Login Error
Close
What are slate floor cleaning mistakes to avoid?
by DoItYourself Staff
When it comes to slate floor cleaning, you must be careful to prevent damage to the material. One common mistake is vacuuming the slate floor with a hard bristle attachment. By doing this, you can scratch the slate flooring so that it can not be repaired.
When you are cleaning slate flooring, you also need to make sure that you do not use any types of cleaners that have acid in them. You should not even use vinegar on slate as it can permanently etch or discolor the surface.
 forum activity
