What Cookware to Use With a Ceramic Cooktop
A ceramic cooktop is a great addition to any kitchen. It is easy to clean and maintain, and with proper care, it will look like new for years. An important part of ceramic cooktop care is the cookware you use on it. Unlike traditional gas or electric stoves that have burners or coils, ceramic types require gentle handling and care.
Appropriate Kitchen Cookware
All ceramic cooktops require the use of flat-bottomed cookware. Proper alignment between the cookware and the cooktop is essential. Avoid pots and pans with rough bottoms because they can cause scratches on the surface. Make sure the size of the heating elements on your cooktop match the bottom area of the cookware.
Cookware Material
Avoid copper utensils because this material can melt, causing irreparable stains on the cooktop. You should also avoid glass cookware, which can shatter due to high heat. The best materials for use on a ceramic cooktop are stainless steel, cast iron, and solid aluminum cookware. Always make sure there is no copper content in the metal. Also, avoid utensils with painted bottoms. At high heats, the paint may melt and fuse with the cooktop, which could require a costly replacement.
