What Is a Hoist Clothes Line?
A Hoist clothes line is a type of a clothes line that is used by people who have larger loads of clothing that they need dried. This type of clothesline looks different than the average one. Instead of being one long line, it is a rotary clothes line.
Height
One of the best things about a Hoist clothes line is the fact that it is height adjustable. You will be able to make it as high or as low as you need it to be. It is recommended that you do not allow your laundry to hang too low as it can get dirty or children or pets can pull it down.
Materials
These types of clotheslines are typically made of galvanized steel and aluminum. These materials will be able to hold even heavy quilts and blankets.
Space
These types of clothes lines will require a large amount of space so that they can properly hold your clothes. You will need to make sure you can provide around 20 feet of space.
Permanent
You will need to make sure that you are aware that this clothesline does not collapse. It also must be fixed directly into the ground with no socket.
