Login Error
Close
What is a Shower Base?
by DoItYourself Staff
A shower base is the part of the shower where you stand. It is the most important part of the shower because it also serves as the water basin for water to drain. Properly drained water won't damage the floor, sub-flooring and walls in your bathroom. An improperly installed shower base could lead to serious water damage, mold or other related issues.
What a Shower Base Is Made From
A shower base may also be called the tub. Shower bases are generally made from a hard and sturdy acrylic. They contain a chrome drain, which is necessary for water drainage. You can find a shower base in a variety of colors and styles to match the décor of your bathroom.
Installation of a Shower Base
Installation of a shower base typically takes place at the time the home is built. You might also install a new base if you later remodel your bathroom. Many people hire a professional installer or contractor for this job. However, a skilled do-it-yourselfer who has worked with bathrooms and showers can also accomplish the task.
If you decide to install a new shower base, take care that all seals and protections are in place. These seals prevent the shower base from leaking.
 forum activity
