Login Error
Close
What Is a Slab Foundation?
by DoItYourself Staff
Among many types of foundation used for construction of a building, a slab foundation is no longer as popular as it once was. There are more cons associated with it rather than pros.
What is Slab Foundation?
A slab foundation is a foundation that is made of a concrete slab. Slab foundations are often laid over the top of soil-based areas. They provide an easy method of setting a base foundation by simply pouring the slab foundation mixture over the area and leaving it to harden. Slab foundation can also be purchased and laid in concrete blocks. Slab foundation offers a quick, cheap, and easy method of laying a foundation.
What are the Pros of Slab Foundation?
Slab foundation can be purchased at a much cheaper cost. As the cost of the foundation is cheaper, it also reduces the cost of purchasing a house made of slab foundation. Slab foundation offers the option of adding additional space, as foundations are easily extended. The slab foundation is very strong and hard, which offers a strong flooring material that is unlikely to break. The foundation is very easy to lay by simply placing the concrete blocks down or pouring the slab over the designated area.
What are the Cons of Slab Foundation?
Due to installation techniques, electrical systems may be difficult to access when there are issues, as they are often installed below the slab foundations. The floor is very hard, which although it offers stability, can be uncomfortable. A slab foundation home can be very cold due to the lack of thermal cover and heat containment. The foundation also lacks water resistance, so it can get very damp. Cracks easily occur in slab due to the hardness of the material.
 forum activity
