What is a Slide in Electrc Range?
If you are considering the purchase of an electric range for a new home, newly remodeled kitchen, or to replace an existing range, you should know more about a slide-in electric range as one of your options. To choose the range type that better fits you needs you will need to know certain things such as your kitchen design, your spending budget, etc. By reviewing the following information, you can make a better determination as to whether a slide-in range or a stand alone will be the best fit for you and your kitchen.
Cost Comparisons
A slide-in range is a good option if your budget is limited. The cost of a new slide-in stove, by comparison, can range from $200 to $2,000, depending on what options you choose, while a stand alone can cost as much as $3,000.
Integrated Appearance
A slide-in range can be a good choice for the home owner who prefers a more integrated look, one where the range and the cabinets appear more as one unit. The reason for this appearance difference is that a slide-in range model stands on its own, while with a freestanding range, the sides of the cook top are contoured. The contour extends over the counter top edge on each side of the range, preventing food, spills, etc., from falling between range and counter top. The freestanding model also provides a custom look to your kitchen. You should be aware that in order to consider a slide-in range, you must have cabinets on both sides of the space where your range sits. Before you make a purchase of any range it is important that you take careful measurements of your stove and cabinet space, as the widths of ranges can vary from model to model.
Storage Drawer Feature
A slide-in range has a feature that can be more convenient, particularly if your kitchen lacks cupboard space. Most models have a drawer located on the bottom of the range where you can store cookware or bakeware.
Control Panel Location
Unlike a stand-alone model which has controls on the top rear panel, a slide-in range has controls on the front of the range. This is a convenient feature if you prefer not to reach over your cooking pots to adjust controls on your stove. On the other hand, front control panels can be a hazard if you have small children who may be tempted to play with the controls.
Miscellaneous Features
Many feature choices are available in slide-in ranges, just as there are with other electric stove models. You can choose between three types of cook tops: regular coils, solid disk elements, or smooth top surface. Although a smooth cook surface is the easiest to clean, some cookware can not be used on this type of surface.
There are also oven factors you should consider, such as cleaning options. However, keep in mind that more options usually means more cost. So, when you compare features, compare costs, also.
