Login Error
Close
What Is a TFT LCD Computer Monitor?
by DoItYourself Staff
A TFT LCD computer monitor is the new innovation in computer technology. Nowadays, you can find TFT LCD computer monitors replacing the older CRT monitors. This innovation is a variant of the LCD, which uses the matrix structure of TFT or thin-film transistor. The TFT improves the quality of the image being displayed in an LCD, or liquid crystal display monitor.
LCD and TFT: Is It the Same?
Although most LCD monitors are TFT LCD, it is important to note that not all LCDs are TFT, although all TFT are considered to be LCDs. There are some LCD computer monitors that are non-TFT display. A non-TFT is often referred to as a passive matrix, while a TFT is called active matrix. Simply put, a TFT display is a type of LCD.
A non-TFT features a shine-through backlight, making it much slower than a TFT LCD. It also provides a fuzzier image quality, making it an unpopular choice in computer monitors.
Why a TFT LCD Computer Monitor?
The TFT LCD computer monitor has great advantages from its predecessor. It is more compact and weighs less than the old CRT screens. A TFT LCD computer screen also has lesser power consumption. Aside from this, this type of computer monitor has no geometric distortion, meaning that the quality of the images is more pristine than the older version. It also has little flicker or none at all, depending on the backlight technology used. A TFT LCD computer screen has additional matrix of transistors which is paired with LCD panel. You will find that there is each RGB has a separate transistor for each pixel, which helps in creating a higher image quality.
 forum activity
