What Is An Electrical Junction Box?
An electrical junction box is a very important part of your electrical wiring system. Without a junction box, you simply cannot have many different types of electrical outlets, switches, or data hook ups in a room.
Control Box
The electrical junction box is the place where all the wires in a room, or wiring area, are joined together and fed by the main breaker. Junction boxes can then be called a control room of sorts. They send power from the main breaker to the other parts of the room. These junction boxes are usually hid behind the drywall, or paneling as they serve no aesthetic function.
Metal or Plastic
An electrical junction box can be made of either metal or plastic. They usually measure 2 1/2" deep or 3 1/2" deep. The larger of the two being able to hold up to five different wires, while the smaller only three.
Needed for Several Installations
If you are going to be installing several different types of electrical components in a room, then you will need to tie into the existing wiring somewhere. A junction box makes that easier by allowing you to connect directly to the main breaker. This negates the need to running wire through the entire house back to the breaker.
