What is Elastomeric Sealant?
When a project calls for sealing, finishing, or protecting a surface, an elastomeric sealant is a must. When you need to fix water leaks or seal a surface as part of its regular maintenance, you will most likely use one. Find out more about elastomeric sealants below.
Surfaces You Can Use with an Elastomeric Sealant
An elastomeric sealant can be used in various surfaces such as stone, steel, concrete, and other polymers. Thus, you can use this kind of sealant on floors, driveways or roadways. It's your best bet when you need a moisture-tolerant and elastic sealant.
Elastomeric Sealants for DIY Projects
Aside from the industrial uses, elastomeric sealants are also used in home projects or DIY projects. You can use it to seal windows and doors, showers and tubs, sinks and toilets, and countertops and backsplash among other high movement joints.
This means you can also find an elastomeric sealant that can be used on drywall, masonry, vinyl, glass, metal, wood, porcelain, and plastics.
Sealants for Roof Sealing
Aside from the projects mentioned previously, elastomeric sealants are also used for sealing roof. So if you are experiencing water leaks, you will need to apply an elastomeric sealant to your roof. This is common for roofs made up of concrete and are more than 25 years old.
