Login Error
Close
What Is Piano Finish Laminate Flooring?
by DoItYourself Staff
If you've been wanting to add an attractive, highly resilient type of laminate flooring to any area of your home, make sure to consider piano finish flooring. This unique variety of laminate flooring will give any area in which it is installed a sleek, classy appearance.
Namesake
Piano finish laminate flooring is essentially high quality wood flooring that features a shiny high gloss finish. The finish gives the floors a smooth, sleek appearance that bears a strong resemblance to a grand piano. This type of flooring meshes nicely with both contemporary and older houses and is often found in formal living rooms. Incidentally, piano finish laminate flooring makes a fantastic surface upon which to place a grand piano.
Upkeep and Maintenance
In addition to looking great, piano finish laminate flooring is very easy to maintain. Dust can be removed with a run-of-the-mill broom and dustpan. If you're looking to give your piano finish flooring a thorough cleaning, simply combine a mixture of white vinegar and warm water in an empty spray bottle, apply it to any filthy areas and proceed to wipe the floor clean with a sponge or nonabrasive washcloth. Follow up by spraying the freshly cleaned floors with water and giving them one final wipe.
 forum activity
