Login Error
Close
What Is the Average Refrigerator Weight?
by DoItYourself Staff
As refrigerators come in a range of models and sizes, it is clear that the average refrigerator weight can be exceedingly difficult to calculate. However, calculating the weight of a refrigerator can be useful if you are hoping to have it removed, or are planning to sell an old one for scrap. There are so many varieties of refrigerator, from small half-height models to side-mounted fridge-freezers that are taller than the average human being. The differences will also be affected by the age of the refrigerator, how heavy the internal engine is, and many other calculations.
Older Refrigerators
If you have a refrigerator that is more than around 15 years old, then you will most probably have a heavier than usual fridge. These can weigh as much as 250 pounds, which is nearly 100 kg. In addition, they may have larger propulsion tanks fitted internally, and other electrical items which will be heavier than the more modern varieties.
Newer Refrigerators
Refrigerators that were built after around 1995 will be lighter, and often feature removable parts that can be unscrewed prior to lifting. The average refrigerator from this age will weigh a little more than 200 pounds, which is equal to 90 to 91 kilograms. This calculation can of course be affected by the size of the fridge, and whether it is a combination machine.
 forum activity
