What Is the Best Energy-Efficient Window Type for Hot Climates?
With the best energy efficient window, you can control the temperature within your home and make the space cooler during hot summer days. The right windows will allow sunlight to pass through, but block heat, helping you save both energy and money on air conditioning. Follow the tips below when choosing the type of energy efficient windows that work best in hot climates.
Selecting Window Frames
The type of window frames you use will have a great impact on the energy efficiency of your windows. Frames may be made of several different materials, including aluminum, fiberglass, vinyl and wood. Aluminum frames, though widely used in modern construction, are the least energy efficient. Fiberglass frames are moderately efficient. Wood and Vinyl frames are highly efficient. Wood frames are costlier while vinyl frames are affordable.
Window Glasses for Energy Efficiency
The glass panels contributes to the energy efficiency of a window. There are 3 factors to consider for the types of glass:
- Visible transmission (VT)
- Solar Heat Gain coefficient (SHGC)
- U-value
VT is the amount of sunlight that is transmitted through the glass, while SHGC is the fraction of total solar heat that can pass through the glass. U-Value is a measure of transfer of heat through the glass through conduction, convection and radiation.
Glasses with high VT allow significant daylight into the house thereby reducing the necessity of lights during daytime and hence help in saving energy. The recommended value for VT is 60 to 80 percent. For hot climates SHGC must be as low as possible. Glasses with low SHGC let a lesser fraction of solar heat into the house and thus help in saving the air-conditioning bills. SHGC of below 0.40 is recommended for places with hot climates. The glasses with low U-Value is recommended for all climates.
Use of Multi-Pane Glasses
Single pane glasses are highly inefficient and no more used. Use of double or triple pane glass is recommended for energy efficiency. The vacuum created between different panes of multi-pane windows is what causes insulation and hence helps in saving energy.
For best energy efficiency, there has to be a perfect vacuum between panes and that is possible if the glasses are very thick. Hence various gases are used between panes to create insulation. These gases are better insulators than air and hence help in saving energy.
Argon is most commonly used due to its efficiency and affordability. Krypton is used for special glasses which are very thin while xenon is rarely used due to its high cost.
Low Emissive Glasses
Low emissive glass panes are also used to improve energy efficiency. Low emissivity glass has a coating of metallic oxide layer on the inner side. The low emissive coating prevents heat transfer between panes i.e. from glass of high temperature to the glass of lower temperature. For places with hot climates, the low-e coating needs to be applied to the inner side of the outermost pane. Low solar gain low emissive glasses reduce the incoming heat and form the best energy efficient windows for hot climates.
While purchasing and selecting windows, it is recommended that you look for NFRC ratings.
