Login Error
Close
What is the best way to clean the edge of cut marble tile without causing corrosion?
by DoItYourself Staff
To clean the edge of cut marble tile without corroding the material, you will need to use mild detergents and non-abrasive tools. The tool for the job is simply a cloth because this is smooth and gentle. If you can use it on your face, then it is safe to use on the edge of a marble tile. There are many mild detergents out on the market from hand soap to dishwashing liquid, but here is a quick and easy recipe if you want to make your own: Squirt a generous amount of dishwashing detergent into some water. Add ¼-cup of rubbing alcohol for extra disinfecting power. Clean the tile edge using this solution and a cloth.
 forum activity
