What is the best way to hang a garage pegboard?
One of the best ways to organize tools in your garage is to use a garage pegboard. When hung where it will be close to your workbench or work area, it will help you keep track of your tools and make it more convenient for you to reach them.
Cut two-inch-by-four-inch pieces that will fit at the sides, top, and bottom of your pegboard. Screw these frame pieces to wall studs, then attach your pegboard to this frame. This will position the pegboard with space between its rear surface and the wall it's attached to, allowing you to position your pegboard hooks where they will be more convenient.
