What is the best way to install a tile mural in my kitchen?
A tile mural in a kitchen gives the entire room look as though it's been designed by a custom decorator. You can use a murals of any size or design depending upon your taste and decor. The mural should be designed and laid out on a flat surface so you can work out any design problems before you apply it to a wall. You can then apply the tile directly to the existing wall. If you wish to make the mural portable in case you move, build it on backboard and then hang the backboard on the kitchen wall. You can add an edging to the backboard to make it look like a custom installation that is permanent.
