Login Error
Close
What is the best way to paint a fiberglass boat hull?
by DoItYourself Staff
Of course, spray painting, using an air gun and compressor, is still the best way to paint a fiberglass boat hull to achieve that "professionally made" look. However, not all DIYers have an air gun and compressor, or have the skill to use the equipment correctly. If such is the case, it can be said that the best way to paint a fiberglass boat hull (by both novice and expert) is the roll and tip method. This method usually requires 2  people to do the job, 1 to do the paint rolling, and the other to run the tip of the brush lightly over the paint, at a 45 degree angle, until the paint self-levels on the surface.
 forum activity
