Login Error
Close
What is the Difference Between Diagonal Pliers and Symmetrical Wire Cutters?
by DoItYourself Staff
Many people find it difficult to distinguish diagonal pliers from other cutting tools. They usually do not know the difference between diagonal pliers and symmetrical wire cutters. Pliers are hand tools that are used to grab and hold objects securely as well as cutting and bending such material, example of which is wire. The jaws of a pair of pliers are important because they are used to handle certain objects that may be too small for you to hold with your fingers.
An ordinary pair of pliers is composed of two levers affixed together with a fulcrum situated closer to one side that to the other. The shorter sides are the jaws of the pliers and the longer sides are the handles. In this manner, when you use the pliers to cut wire, the structure of the pliers allows the strength of your hands to focus on the wire so that you will cut it correctly and without any unnecessary movements.
What Are Diagonal Pliers?
Diagonal pliers are specifically used to cut wire. They have various names, i.e. side pliers, side cutting pliers or diags. The name given to these pliers differs also in other countries e.g. they are called snips in Ireland and the United Kingdom, but on the other hand, in Canada and Australia, they are called side cutters.
People are generally confused because there are many different types of pliers and each type can be used for one or multiple jobs. These pliers are so called for its intersecting jaws cut wire at an angle. Unlike pairs of scissors, they do not only cut the wire, but they can form indentations and wedges in the wire.
For security reasons, it is advised that you insulate the handles of your pliers so that you will not be electrocuted in case something goes wrong. They can cut through live wires and others that are made from metal i.e. iron, brass, steel, copper and aluminum. You should be careful when you are using the pliers to cut live wires because it is a dangerous job.
Diagonal pliers need to be made of tempered steel in order to be strong enough for most wire-cutting jobs. Other pliers may not be suitable because they are made of softer material and the jaws would not be powerful enough to cut the wire.
Flush Cutters vs. Symmetrical Wire Cutters
Electricians utilize diagonal pliers at work and they like to call them flush cutters to distinguish them from symmetrical wire cutters. You must keep in mind that you should use a flush cutter only on flat surfaces. You can use a flush cutter to create a chain by attaching a number of rings to each other. Symmetrical wire cutters leave the wire with a pointed tip after they cut it, but flush cutters do not.
Flush cutters enable you to cut wires that are very close to their base. You do not have that ability if you are using a symmetrical wire cutter. This is done because the jaws of a flush cutter are angled and narrow, whilst the handles are lifted away so that you have enough space to hold the handles securely. Flush cutters can be also used to trim the wires as well, not just cutting them.
 forum activity
