Login Error
Close
What Is the Ideal Home Humidity Level?
by DoItYourself Staff
Maintaining a proper home humidity level is essential for your well-being and that of the home. Extreme fluctuations cause adverse effects on both. Low humidity may cause respiratory problems and damages on wooden doors, windows and furniture, and make you vulnerable to electric shocks due to increased static electricity. On the other hand, high humidity will result in molds that serve as breeding ground for bacteria, resulting in poor health and a damaged home.
That being said, maintaining optimum levels of humidity indoors is essential for the health of your family and home. Average humidity levels should range between 30-50% percent. However, experts suggest ideal humidity levels in the home should be close to 45% for optimal health.
Measuring Home Humidity Level
Humidity levels can be easily gauged with a hygrometer. This device is employed to calculate relative humidity in the surroundings and monitors the humidity levels at home.
Other effective way to check the humidity level indoors is by performing the ice-test. Put three ice cubes in a glass of water and stir it a few times, wait for 3 minutes. If moisture droplets fail to form on the exterior walls of the glass, the indoor air is very dry, and a humidifier is required to moisten the air for optimal health.
High humidity levels will result in the fogging of windows too often. This indicates the build up of mold and moisture on walls and ceilings.
 forum activity
