What is Trisodium Phosphate or TSP Cleaner?
Trisodium phosphate is also known as TSP and is an agent that is primarily used for cleaning. It is also an additive in food and a stain remover. The look of this agent is white and it is made from solid crystals. They dissolve in water and create a solution that is alkaline in nature. It can also be found in white powder form in some cases. It was regularly used in soaps and detergents in the past and is very popular.
Uses
The main use for trisodium phosphate is in agents needed for cleaning. As it is mainly alkaline, this means that it is fantastic for cleaning grease and oil stains amongst others. It is used in combination with other detergents and is great for cleaning clothes in particular. However, it is also used for cleaning concrete driveways and paths. The fact that it is so versatile means that it is often purchased by many. However, TSP is not that great at cleaning bathrooms, as it can erode the metal taps and damage grouting. Additionally this substance can also be used for joints in copper pipes in order to repair and resolve problems. The common uses are cleaning, though, and it can break down grease and oil with relative ease. Other uses for this substance are in your garden or outside your home. It can remove dirt and debris from your grass and also from equipment in your garden. If you mix this with bleach, then you can make furniture outside look like new. It is also very good for getting rid of mildew that builds up on wooden decking and boards.
Be Safe
Despite how good it is at cleaning, trisodium phosphate is very strong and you should always wear protective gloves and eye protection when using so as to stay safe. If the cleaner comes in contact with the skin, then it can cause major irritation and also burns if you do not use is correctly. Rubber gloves will help you avoid this when using it and also long sleeves and goggles to protect your eyes. Ensure that the substance does not touch bare skin. If it does happen, however, then you should wash that area thoroughly with soap and water and ensure you stop using if your skin becomes red and is sore. You may experience irritation for longer periods as well as blisters. Additionally, it can be very painful if you let it get in touch with your skin. If you let it get near your eyes then you should rinse out your eyes with clean water and do this for around 15 minutes or so. You should also seek medical attention as soon as possible. If the cleaner is consumed by mistake, then you should not vomit if you can help it. Instead, drink water or milk and then seek medical attention quickly. This particular cleaner is strong enough to cause damage to household surfaces and wooden areas. If you have surfaces that are painted too, then this can be damaged and the colors worn off. If you want to avoid this, then you should put down masking tape to prevent damage.
