What Makes a Good Laminate Floor Vacuum
It is important to choose the right vacuum for your laminate floor. If you want to avoid scratching, tearing and general wear and tear of your laminate floor, you should use the proper vacuum. Here are a couple things to consider in your choice for a laminate floor vacuum cleaner.
No Beater Bar
The best type of vacuum for a laminate floor must not have a beater bar. A beater bar is usually found as an attachment in a canister vacuum cleaner. The beater bar will scratch the surface of the laminate floor. Avoid it at all costs
Stick Type
You will want to find a vacuum cleaner that is a stick vacuum cleaner. This appliance or household device will clean your laminate floor the best. It will get rid of the dust and the grime, and it will not cause the floor any harm. It will help resist any scratching or other problems that are common when using other vacuums.
