What to Avoid When Working With Shellac
There are several things to avoid when working with shellac. It has its advantages, but it also possesses several disadvantages.
No Alcohol Drips
Shellac will re-dissolve in alcohol and alcohol-based perfumes allowing beverages like whisky or any expensive perfume to mar a shellacked surface.
Water Rings
Wax-laden shellacs form white rings when water comes in contact.
Wax On
Although shellac is a formidable finish for all wood products, it is susceptible to showing scratches. Therefore, wax applications will help reduce scratch visibility.
Shelf Life
Once mixed with alcohol, shellac has a defined shelf life. Most wax-free shellacs are limited to six months. Wax-laden shellacs will last longer. They must be store in airtight containers to elongate shelf life.
Cleaning Hurts
Shellacked surfaces are subject to damage when using household cleaning compounds that include alkaline chemicals like lye and ammonia. These products can mar the surface area causing discoloration due to its acid composition.
Heat Hurts
Shellacked surfaces should not come in contact with very hot items. It will start to melt at 150 degrees. Therefore, use of coasters and trivets is always recommended to protect shellacked surfaces. If, for example, a cup of hot coffee is placed directly upon the surface it can cause discoloration and marring.
