Login Error
Close
What to Consider when Buying a Solar Tube Light
by DoItYourself Staff
Buying and installing a solar tube light is the best way to give a home or building an incredibly beautiful lighting solution. Not only does it mean enjoying exceptional lighting, but it also means getting a truly cost effective lighting option. Solar tube lights can also be installed quickly and easily. Best of all, these lights are so compact and flexible that they can be installed and used in any room, even those that do not get direct sunlight.
Before shopping for solar tube lights, it is important to know what to look for.
Buy a Recognized Brand Name Product
Buying the solar tube lights from a recognized brand will ensure getting the best of cutting edge technology and not having to settle for copied products and designs. In addition, products bearing a recognizable brand name will also provide higher quality and more innovative lighting solutions, so stick with a big name product.
Look for Technology
A product that has been created by using innovative technologies will provide superior lighting, and it will also be made from special materials (like reflective tubing) that will transfer much more daylight than regular materials are able to do. This translates into getting the cleanest and brightest as well as best natural lights.
Go With Energy Star ® Products
Energy Star ® is a well known rating system that measures energy efficiency, and any product that has their label will have met the strictest requirements as laid out by US Department of Energy as well as by the Environmental Protection Agency.
Look for Long Term Solutions
There is no sense in scrimping, as this will only provide short term gains. When purchasing solar tube lights, be sure to look for features that will ensure that no costly repairs will be necessary further down the road.
Look for Adaptability
It pays to look for solar tube lights that can be installed wherever desired, including in spaces that are very narrow and also in rooms that do not directly receive sunlight. There are products such as 0 to 90 degree extension tubes that will ensure that even the most difficult installation requirements can be addressed without compromising on quality.
Look for Functionality
It pays to go with solar tube lights that are easy to accessorize with, for example, a Light Add-on Kit or even a Ventilation Add-On Kit, which is ideal for locations that are plagued by dampness.
Beauty Matters
Finally, instead of choosing an all in one model, be sure to look for those models that are attractive and beautiful and which help to give the ceiling a more unique look, while at the same time allowing for customization as well.
The bottom line is that solar tube lights make for a wonderful addition to every home, as they provide light just like a skylight. At the same time, these lights can be installed without needing to make any changes to the structure of the building, and they are affordable as well and can be purchased for between 200 and 400 dollars. All that remains is to pick a solar tube light of a size that is large enough to properly illuminate a given space.
 forum activity
