What to Consider When Buying Deck Stain Remover
With the use of a good, quality deck stain remover, you can easily transform your deck from dull to elegant in just a few days. After years of sitting in the sun, rain, snow and cold, a deck can start to look pretty ragged. This is not because of the wood crumbling, but because of the way that the deck stain begins to fade and lose its color. Using a stain remover will help you get back that great look. If you have never bought any type of deck stain remover before, here is some information on what to consider when making your purchase.
Size of Deck
Some deck stain remover is best used in small amounts because of the strength of the chemicals involved. If the deck is large in size, then you should look at those types of deck stain removers that do not contain a lot of acids.
Location of Deck
In this day and age, you must be careful about the type of cleaning products and stain removers that you use. This is especially true if you live near a water source or a wetland. The chemicals that are contained in many cleaning products will be absorbed into the ground and leak into the groundwater. There are deck stain removers that contain chemicals like trisodium phosphate. This is quite harmful to the environment in large doses. If you have a large deck, then there is the possibility of contaminating the nearby water area.
Acidic Content
If you want to get the top level of stain off of your deck then oxalic acid is a great option for you. This type of stain remover works very good and is not as hard on the environment as the harsher types of chemicals.
Restoring Natural Wood Color
When looking to buy your deck stain remover find out which one is going to be able to return the natural look to the wood. Even after a few years of sitting in the sun, the wood will be protected if the stain was applied correctly. Once a deck stain remover strips away the layers of the stain, grime, mildew, and other things that have embedded itself into the tiny cracks of the wood you are left with the original wood. Once you sand it down and replace the stain you should be left with the natural, shiny look of the original wood.
Consider Biodegradable Products
There are plenty of different biodegradable deck stain removers on the market today. While they may cost a little more than some of the deck stain removers, they are worth the extra expense. As the deck stain remover is rinsed off of the deck by hoses, it will seep into the ground and end up in the groundwater. A biodegradable product will quickly dissolve and not harm any other water or plants.
Multi-Use Stain Remover
When purchasing your deck stain remover it will help to get something that will provide the most bang for you buck. Consider the remover that will work on oil based stains, latex based stains, polyurethane, varnishes, clear stains and dark colored stains. This will make sure that you will be able to remove the stain on your deck no matter what type it is.
