What to Consider When You Replace a Sewer Line What to Consider When You Replace a Sewer Line
In order to properly replace a sewer line, there are a few things that you are going to have to keep in mind. You will find that understanding the basics of what it means and what it will do will help you to get the job done quickly and effectively. Replacing a sewer line is something that is going to become necessary over time. You will simply need to make sure that you are able to know what to expect both during and after the process so that there are no unwanted surprises for you. Basics The first thing that you should know is of course the basics. There is actually more than one kind of system out there. The main sewer line is the line that is basically the lifeline of your plumbing system. If the sewer line did not exist then there would be no way that you would be able to get rid of the waste at all. PVC pipe is the main type of pipes that are now used when it comes to this type of piping. This is because they last long and are extremely durable. If this pipe is in a commercial location, then it may be cast iron that is used for the piping. Your sewer line will run all the way from the building it is hooked up to and go into either a septic tank or the actual city sewer hookup. The length of your line is actually determined by getting the measurements of the inside of your building or wall and going to the sewer hookup or the septic tank. Preparation Before you even begin to install your new sewer line, you are going to have to first get a basic understanding of your local plumbing codes. You are going to need to see the depth requirement so that you will have a good idea of how far you will need to dig. Once you know how long and how deep to dig you can begin to make plans for exactly how you will go about doing this. You can make a trench by hand if you do not have far or deep to dig. However, a backhoe is something that is commonly used and necessary. Make sure that you follow the plumbing code carefully so that you will be able to get the job done right. Installation Whenever you are installing the pipes, you will need to know what your state's requirements are. Some states will need to make sure that the pitch that is on your pipe has a grade of ¾ of an inch for every 4. This of course will vary from state to state. Inspection Once you have the pipes in place, you will need to have a plumbing inspector come out to see the pipes. Make sure that you do not burry the entire pipe so that they can see it. However, it may be a good idea for you to bury parts of the pipe to make sure that it stays in place.
In order to properly replace a sewer line, there are a few things that you are going to have to keep in mind. You will find that understanding the basics will help you to get the job done quickly and effectively. Replacing a sewer line is something that is going to become necessary over time. You will simply need to make sure that you are able to know what to expect both during and after the process so that there are no unwanted surprises for you.
Basics
The first thing that you should know is of course the basics. There is actually more than one kind of system out there. The main sewer line is the line that is the lifeline of your plumbing system. If the sewer line did not exist then there would be no way that you would be able to get rid of the waste at all. PVC pipe is the main type of pipes that are now used when it comes to this type of piping. This is because they last long and are extremely durable. If this pipe is in a commercial location, then it may be cast iron that is used for the piping. Your sewer line will run all the way from the building it is hooked up to and go into either a septic tank or the actual city sewer hookup. The length of your line is actually determined by getting the measurements of the inside of your building or wall and going to the sewer hookup or the septic tank.
Preparation
Installation
Inspection
Once you have the pipes in place, you will need to have a plumbing inspector come out to see the pipes. Make sure that you do not bury th
