What to Know when Buying a Used Boat
Buying a used speed boat is the best option for people who want to save money as they start out with their boating hobby. A secondhand boat is also a good choice if you are only going to use it occasionally during weekends or vacations. However, buying a used watercraft can be risky. You need to exert due diligence before deciding to buy a used boat. Below are some of the things that you have to know before you buy a pre-loved boat.
Price
When buying a used boat, price is an important consideration. You should ask around for the fair market price of the boat model or type that you want so that you will have a guide as to how much money you need to spend. Look for books, newspaper ads and websites that provide price guides on used boats. Just remember, a low price does not necessarily mean a good deal. You might need to spend a lot more for engine maintenance, body reconditioning and other refurbishing expenses if you settle for the cheapest speed boat.
Appearance
Another important factor in buying a pre-owned watercraft is its appearance. Check the painting and finish carefully. Make sure that there are no paint coat blisters. If you do not mind having a dull looking paint job on your boat, then chalking can be acceptable especially if the price of the boat is right. Some of the things that you should carefully look into are upholstery and overall condition of the hull. Rips and discoloration in the upholstery can be a sign of improper storage and maintenance. Mismatched paints can also be an indication of past accidents. Moreover, you should check if the floorboards are rotting due to rust.
Performance
It is also important that you test drive the used speed boat that you are considering. You cannot gauge the performance of the craft by merely looking at its engine and appearance. Pay close attention to how the boat responds to your steering and gear shifting. You should also be sensitive to vibrations and noise made by the engine and propeller. Check if all the gauge instruments are functioning. It is a good idea to bring companions with you when you test drive the boat. Doing so, you not only gain other people’s insights, but you will also be able to effectively measure how added weight can affect the boat’s overall performance. However, it is important to avoid overloading the boat.
Speed Boat Condition
The boat’s use is measured by hours not distance. However, the hours stated on a speed boat is not a definitive guide as to its condition. A boat with under a hundred hours may not be a good buy if the previous owner does not maintain and store it well. Thus, it would be a good idea to ask the seller about the maintenance history of the craft. You should also check if the engine, seals, and gaskets are clean and grime free. Make sure that steering cables are connected properly and the propellers are not chipped or damaged. If you do not know anything about a boat’s engine, you can always get help from an experienced marine mechanic.
