What to Know When Choosing and Installing New Gutters
New gutters can present a big challenge when working on your house. Not only will removing the old gutters and putting up new ones be a major job, but new gutters can also change the entire look of your home. This means that making the right choice in guttering is important not just for functionality, but also for design. Read on to learn more about different types of gutters and how they work so you can decide which will best suit your needs.
Gutter Materials
There’s a wide choice of materials for new gutters. You can opt for galvanized or stainless steel, copper, aluminum or vinyl. The last two are the most popular choices with vinyl now being more popular than anything else. Much of this is down to the durability and ease of installation of vinyl as well as the price. All three are vital factors especially for those on a tight budget. With vinyl, almost anyone can install new gutters on the house. Good quality vinyl guttering will last for many years.
Types of Gutters
There are two types of gutters to consider when you look at new gutters for your home. The first is the standard form of sectional guttering where the new gutters are put together piece by piece. This is the type you can assemble yourself and it can cut down on installation costs.
The other type is seamless guttering. This is professionally installed and the entire length of each gutter is a single piece. The great advantage to this is that it eliminates the possibility of leakage from the seams which can frequently occur with sectional gutters. The downside is that the installation is far more expensive.
Gutter Guard
These days, many people opt for gutter guards which are screens that fit over your gutters and keep leaves and other debris from clogging them. This can be an excellent investment as it means you won’t have to get on a ladder every year to clean out the blockages yourself.
Brackets
When you’re installing gutters, make sure you use enough brackets to properly support them. They should be placed every 24 to 30 inches along the length to avoid possible sagging. When putting up new gutters, don’t attempt to skimp on materials. In the long run. it will prove to be a false economy.
Slope
There’s more to installing new gutters than simply putting them on the house. Gutters are only really going to work if there’s a slight slope toward the downspout but it shouldn’t be to steep. What you ideally need is a slope that goes down just 5/8-inch for every 10 feet of length. It’s best if you use a chalkline as a guide for your guttering.
Sections
When you’re attaching gutter sections, you need to use a bead of silicone caulk between them to avoid the possibility of leakage. Put the mounting brackets up first then fit the sections and gutter connectors. The downspout should be the final part of your new gutter installation. Once it’s firmly attached to the gutter, you should use brackets to keep it in place against the structure of the house.
