Login Error
Close
What to Look for in a Truck Bed Organizer
by DoItYourself Staff
Truck bed organizers can be used for many reasons. Whether you need your bed to be completely organized for a specific job, or just something to hold the groceries from the store to the house, the options are limitless. To help you narrow your search, here are some things to keep in mind.
Cargo Bars and Nets
If you like to use your truck bed for several different purposes, you may want to consider something that can be easily installed and removed. Cargo bars are a great solution and can be instantly removed and installed at most any point in the bed. Another great way to secure cargo is a simple cargo net.  While it doesn’t separate your cargo, it does a great job at keeping things inside the bed.
Tailgate Organizers
Tailgate organizers are great for stowing little odds and ends that may slide around if not secured. These little boxes attach to the tailgate liner and don’t interfere with other objects in the bed.
Bed Extenders
A two-in-one solution, bed extenders can extend your bed length when extended, and act as a cargo barrier at the rear of the truck when not in use. Many bed organizing ideas can be combined to tailor fit your needs and lifestyle.
 forum activity
