Login Error
Close
What to Look for when Buying 7:1 Surround Sound Speakers
by DoItYourself Staff
7:1 surround sound speakers are wonderful as long as you have a room of sufficient size. A powerful 7:1 system requires a larger room to be fully effective. If the room where you are looking to have speakers installed is a little on the small side, you will better going for 5:1 or 6:1 surround sound. Although a good receiver is vital, you also need to pay attention to the 7:1 surround sound speakers. Knowing what to look for when purchasing 7:1 surround sound speakers will help you to find the best equipment to suit your needs.
Matching Speakers
You’ll get the very best from your speakers if they all have the same harmonic and tonal characteristics. This is known as voice matching. Without this, the sound will become disjointed as it moves from speaker to speaker and your listening experience won’t be anywhere near as good as it should be.
The simplest way to achieve perfect voice matching is to buy a set of matching speakers for your surround sound system or to buy speakers from the same manufacturer.
Speaker Material
Most people give very little thought to what the speakers are made of but choosing the right material is vitally important. Inert speaker cabinet material, such as MDF, has a lower resonance and ultimately produce better sounds.
The material for the speaker drivers, or cones, is also important. Different materials produce different tonal qualities. Silk on the tweeters gives a smoother high end while metal has a sharper and brittle tone. You will need to listen to different types of surround sound speakers in order to decide what satisfies you best.
Also, pay attention to the magnets and voice coils in the speakers. You will want components that are fairly powerful because these will produce a much cleaner sound. With high quality magnets and coils, your 7:1 surround sound speakers will give far cleaner sound on dialog.
Subwoofer
With a 7:1 surround sound system, you need a subwoofer of suitable size with a speaker between 10 to 12 inches in diameter. Buy a subwoofer that’s individually powered as this will give deeper, louder bass sounds which are especially good for music. The bigger the wattage you have in your subwoofer, the deeper the bass is going to be. Some subwoofers even come with their own remote contrlol units so you can control the level of bass.
Center Speaker
The center speaker will be the core of your 7:1 surround sound speakers. Of all the sound that you hear from your speakers, the center speaker handles more than half of it. The size of your center speaker will depend on your other speakers. If you’re using tower speakers, always opt for a larger center speaker.
Surround Speakers
Front and surround speakers need to have the same capabilities in order to gather the best sound from your system. The best surround speakers offer dipole/bipole capabilities. This gives you more freedom in terms of speaker placement because they have wider soundfields. Try and ensure that your surround speakers offer the same capability as your front speakers.
Front Speakers
Satellite front speakers always need a subwoofer. If you want a better low frequency response, buy tower speakers. If this isn’t important, you’ll be fine with bookshelf speakers.
 forum activity
