What to Look for when Buying a Flood Light Bulb
There are several types of flood light bulb available on the market. Presently, flood lights are not only used indoors but outdoors as well, both of which take advantage of the nature of flood lights. Below are the different types of flood light bulbs to help you find the right light bulb for you.
Incandescent Flood Light Bulb
Many people use this type of light for indoor purposes. It can last for 700 to 1000 hours and comes in different wattages which can also be used with a dimmer. Little of the energy consumed by this bulb is transformed as heat, allowing it to consume very little energy therefore saves you a lot in the electricity bill and saves the environment as well.
Halogen Flood Light Bulb
With halogen flood light bulb, its life span is much longer compared to incandescent flood light bulbs although this type of flood light bulb is more expensive it produces a brighter light which is advantageous if used for outdoors. But do take note that halogen flood light bulb’s temperature can go to as much as 300 degrees Celsius. Make sure that this bulb will be placed where it is distant to any flammable objects.
Fluorescent Flood Light Bulb
Fluorescent flood light bulbs are commonly used for lighting big areas such as basements, attics and locker rooms. Fluorescent flood light bulbs come in many different types and features that can be useful when placed indoors. If you are looking for a flood light bulb but in a tight budget, a fluorescent light bulb would be a good choice for you.
Metal Halide Flood Light Bulb
This type of flood light bulb has many advantageous purposes for landscaping and security reasons. Metal halide also has a longer life span and more light with every watt. If you are looking for a flood light bulb to properly light a big place such as sporting events or if you are going to place use the light in a cold area/ temperature then metal halide would be the best choice for you.
Solar Flood Light Bulbs
Solar flood light bulbs are similar to halogen flood light bulbs but instead of being powered by a electric energy, this type of bulb is powered by the energy emitted from the sun. It uses this energy to produce light at night. As an added feature of solar light bulbs, you can also set it to automatically turn on at night and turn off at daylight.
Flood light bulbs come in different varieties that careful considering can be helpful in choosing the right flood light bulb for you. It will not only save you another trip to the home improvement store but also help you take advantage of the unique features of your chosen flood light bulb.
