Login Error
Close
What to Look for When Buying a Porch Light Fixture
by DoItYourself Staff
Choosing a porch light fixture should not be a difficult task as there are many designs and types of light fixtures on the market. The most important thing to keep in mind while buying a porch light is to consider the overall appearance on your house. Outdoor lighting has to be ornamental and functional yet comfortable and serene. A mismatched lighting fixture may take away the charm from the experience of adding flair to the dull porch.
Size
Some entrances are bigger than the usual ones. A big entrance needs more than a small wall fixture to look adequate. Similarly, tall porches can use hanging fixtures for decoration. While going for a hanging light fixture, the light should be fixed at a considerable height as to avoid collisions with taller guests. Chandeliers can be useful in creating an ornamental aura and providing safety around the house.
Climate
An important thing to keep in mind while choosing a porch light fixture is that the fixtures should be listed for use in damp locations. Spending money on expensive hanging lights might turn out to be a waste of money if it gets damaged by moisture or water.
Lighting
Apart from fixture types, the light source can also make a huge difference. The light bulbs used in the fixtures can make a lot of difference when it comes to the effect it produces. There are numerous light sources available in the market. Fluorescent light bulbs, incandescent light bulbs and red light bulbs are widely used to create a bright and colorful effect. Although, the most widely used porch light fixture is the flood light. The type of light fixture to be used highly depends on the type of porch and other attributes contributing to the overall setup of the house.
A porch light fixture should not only be adding value to the beauty but also provide a sense of safety. A decent survey of all the available options can be useful in choosing the best fixture as per the requirement. There are many options available in the market; choosing the right one is the challenge.
Ceiling Fixtures
Ceiling fixtures are ideal for a portico near an entrance as this type of lighting can help to adequately light a considerable area. These lights are simple yet effective.
Lantern Fixtures
Lantern or Wall light fixtures are usually used around the entrance or any exterior door. This type of fixture is highly useful in adding safety and comfort around the house. Use of lantern fixtures is relative. A larger house will require a large light fixture while a small house will require a smaller one. An important thing to keep in mind with the lantern fixtures is that they should be mounted just above the eye level to create an optimum effect.
Post Fixtures
Post mounted light fixtures are highly useful near the entrances and the driveways. Selecting this type of porch light fixture requires buying a post separately, which comes in different sizes and colors to suit the appearance of the porch.
Garden Lighting
To add beauty to a dull garden or to light a beautiful garden, garden lighting can add aesthetic value to the appearance of your house whilst lighting the area adequately and adding safety.
 forum activity
