What to Look for when Buying a Wireless USB Hub
If you've recently found yourself in the market for a wireless USB hub, there are a number of factors to take into consideration before reaching a decision. So if you're looking to make a wireless USB hub a fixture in your home computer set up, read on to learn everything you'll need to know.
Compatibility
One thing to consider before purchasing a wireless USB hub is whether or not your hub of choice is compatible with your computer's operating system. As most PC owners run Windows, make sure that the hub you wish to purchase is compatible with the version you're currently running before committing to buy. Alternatively, if you're running Linux, make sure to select a hub that is compatible with that operating system. Also, if you're a Mac owner, you may need to purchase a hub manufactured by Apple if you wish to run the device in conjunction with Mac OSX. However, as newer Mac computers are capable of running both Mac OSX and Windows simultaneously, you may purchase a Windows friendly hub provided you only wish to use the device in conjunction with the aforementioned operating system. The operating systems with which your hub is compatible should be prominently listed on its packaging.
Number of Ports
The number of ports the hub features is another important factor to take into consideration. If you only intend to run a few devices through your wireless USB hub, you can purchase one with as few as seven USB ports. If you want to run a significant number of devices through your hub, however, you can purchase one with as many as sixteen USB ports. In the unlikely event that you need to run seventeen or more devices through your hub, you can always run another hub through your existing hub. Not surprisingly, the more ports a hub features, the more expensive it is. While a hub's price is somewhat dependent on the brand, standard seven port hubs will run you between twenty and sixty dollars, whereas sixteen port hubs frequently come with price tags of one-hundred dollars or more. If you're like most PC owners, though, a standard seven port hub should perfectly suit your needs.
Signal Strength
Signal strength can sometimes be a determinant factor in whether or not to purchase a certain hub. If you intend to keep your wireless USB hub in the immediate vicinity of your personal computer and USB devices, a hub that features average signal strength should be just fine. However, if you intend to keep your hub more than three or four feet away from your computer, you will probably want to consider a hub that generates a particularly strong signal. Be advised that hubs with potent signal strength can be somewhat pricey and, as many people keep their USB devices fairly close to their computers, hubs with average-to-low signal strength should work perfectly well for most PC owners.
