Login Error
Close
What to Look for When Buying an Outdoor Flood Light
by DoItYourself Staff
Outdoor flood light systems are commonly used in football stadiums, parking lots and for other large-scale projects. In smaller settings, like around the home, they can be used to illuminate flower beds, water fountains or full landscaping, especially when set to motion sensors. Read on to learn what to keep in mind as you shop, as not all outdoor flood lights are designed for the same purpose.
Dusk to Dawn Lighting
For home security purposes, choose a dusk to dawn lighting. These types shut off during the day so you are sure to conserve energy when these lights are not needed. Light signals these flood lights to shut off until the sun sets and then it will automatically turn on again.
Motion Sensitivity
Make sure you consider motion sensitive outdoor flood lights. Not only are they convenient but they provide an easy way to light up dark areas outside your home when you leave or exit access ways. These lights also are important when you drive up your driveway at night since they will light up the moment it senses your car in the dark. You can easily see if someone is trying to sneak up on your car for a possible attack. These light signals usually ward of possible intruders in your home. Motion sensitive outdoor flood lights are also a great way to know if there are people walking in front of your home since any movement will trigger the light.
Appropriate Wattage
Get appropriate wattage of flood lights. Like mentioned earlier, flood light have different uses and purposes. You should not use a flood light that is too bright in your home as this can cause blindness when it illuminates only a small area nor use residential flood lights to try an illuminate a parking lot because this will not be very efficient. A 75 watt bulb would be enough to light a space like your home’s driveway and lesser for lighting up flower beds or fountains.
Energy Efficiency
If you are considering being more energy efficient, there are flood lights using LED that has solar panels. During the day the panels collect solar energy from the sun and when dusk hits, the lights automatically turns on using the stored energy and not electricity. This is one way to save up on energy around your home. This will save you a lot of money the whole year round.
 forum activity
