What to Look for When Choosing Electrical Cable
Choosing the right type of electrical cable is an essential step in properly wiring a house or any other project. There are a variety of different electrical cables out there on the market, and they all have their proper places. Therefore, choosing the proper cable for the application is a critical step of creating a successful electrical system. Many people that have never dealt with electrical systems before might believe that there is only one type of electrical cable. When you go to buy the cable, you will definitely be in for a surprise. There are many factors that you should take into consideration when looking for electrical cable for your project. Here are a few things that you will want to consider when choosing an electrical cable.
Application
One of the most important things that you should consider when buying electrical cable is what it will be used for. The application of the wire is a critical part of deciding what type of wire you should buy. An outdoor installation is going to require a different type of cable than an indoor installation.
When you install electrical cable outside, you have to meet certain requirements. You have to bury the wire underground in order to make it safe for others. In doing this, you have to make sure that your particular wire is alright to be buried. It has to be able to withstand moisture without any problems. If you choose the wrong type of wire to bury underground, you could have to redo the entire system at some point.
Meets Building Codes
When you are out looking at different types of cable, you need to make sure that the kind you get meets the building codes in your area. Each area of the country has their own building and electrical codes that must be met. There is a governing body, depending on where you live, that determines what is safe to install in a residential or commercial application. Depending on what you are doing, you will need to find out what the requirements of the electrical cable are. They will specify a particular gauge that must be used depending on the application. If you simply follow their recommendations, you will select a sufficient wire for what you are doing.
Ampacity Requirements
The amount of amps that can flow through a particular cable is another essential factor that you should consider. When you are wiring a house or commercial building, you need to consider exactly what the circuits will be used for. If someone is going to use several different appliances, power tools, or a home theater system, you need to figure out exactly how much power they need to do so. Once you determine how much power you need, you should select a cable that can provide that and a little more. It is always better to select a cable that provides a little more than you need so that you do not have to redo anything in the future.
